I have an ’00 996 C2.  I recently removed the dash and most of the components down to the firewall to repair the AC baffles and install an new stereo and amps.  Everything is working fine except the airbag light was is on.  I bought a Durmetric cable to reset the system and after multiple resets I still get error codes 20, 26, 28 and 30.  I am sure I missed or damaged something getting everything back together.  Can anyone recommend a place to start looking based on these code?  Alternatively can anyone recommend a place to find more information on these codes.
These codes say your triggering unit(s) are not connected or shorted out. You may need to double check all airbag control box connections.
If Durametric can not reset these then you will likely need a Porsche PST2 or PIWIS to do so.
Thanks Guys,  Finally got some free time to get back to this.  I removed and re-seated the harness plugs at the airbag control unit in the center stack, then reset one more time with the Durametric.  Light is off and everything seems to be working.  Thanks.
