Sir Tools "Sir P 254 Engine Support Bar"  http://www.sirtools.com/stuttgart_05_page_2.pdf
This tool is very helpful when you need to support the engine when you remove the transmission.
It makes pulling the trans much easier. Beats using a floor mounted screw jack. You can tilt the engine/trans to get clearance to pull the brackets out and replace them, move the lift up and down for bolt and slave cyl access etc. Also enables engine tilt to match trans during installation.
http://rennlist.com/forums/996-forum/741797-got-to-use-my-new-p-254-engine-support-bar-for-the-996-yesterday.html
post-30824-0-64922900-1437413171_thumb.j
