I currently run 285-30-18 on the rear and 225-40-18 on the front. I would like more tire choices. Can I change to the 265-35-18 on the rear? The current rear tire is slightly lower than the front by .4 " the new option would be slightly higher by .2" The width of the rear tire would be smaller by 3/4"
It appears there is plenty of space for the taller tire. The clearance is approx. 2" now. the new tire will only raise 1/2". I am not sure why I would need a spacer?
Standard size tyre options for summer and winter tyres are given in the handbook for both 17" and 18" wheels together with wheel offsets.
Sorry, but I'm a little confused.
Seems to me you would want to go with a 295/30ZR18.
Any specific reasons you're thinking about going to 265/35?  Just curious.
Cheers,
