  • Replies 82
  • Created
  • Last Reply
Top Posters In This Topic
Interesting update on the ABS/PSM issue. I dug into the electronics around the various brake/clutch switches. In a manual, I looked up the details on the Brake Light Switch and found that there are three wires: a signal going in (blk), one NO contact (blk/ye) and one NC contact (blk/rd) going out. These should oppose continuity at all times. Using a multimeter, I found that my switch didn't do that correctly. Instead, my switch had four contacts, with two pair being opposing NO/NC. See hand-drawn sketch below.
The part number on the switch was 96312343, which seems to be some generic p/n; certainly not the correct Porsche p/n. My research says 996-613-113-02-M100 is the right one. Correct one is on order from Pelican.
The PO had it switched in December; the shop must have used the wrong part but since the brake lights still worked (one pair of contacts was correct) they left it. Hacks.
post-102693-0-24765300-1440480155_thumb.
post-102693-0-16414500-1440480161_thumb.
post-102693-0-35295000-1440480171_thumb.
Edited by Bay Arean
The first diagnostic was at the smog center; the technician told me 3 systems weren't ready. "Go drive around, at least 100 miles," he said. 200 miles later, here I am.
Next I used my buddy's USB "PCM Scan" tool. It allows you to see the readiness flags for each module, as well as pull trouble codes. It doesn't show any faults.
But I used a real Durametric to get the ABS/PSM fault code earlier today.
Hey let me know if you need access to w PIWIS to resolve. Good job on the rebuild.
The new brake light switch arrived from Pelican today. I tested the contacts and they behaved as would be expected from the wiring diagram. Got on the highway, and sure enough -- no PSM/ABS fault lights and the cruise control worked again! So the conclusion was: in December 2014 the switch was replaced with a similar one but with different internal wiring. One of the two contacts worked correctly, causing the lights to activate but the computer to know something was wrong.
I also tried the "OBD Drive Cycle" again, this time beginning with a cold engine. Followed the instructions to a T, and it was successful. My buddy's scanner showed all systems ready. I'll smog it this weekend.
Looks like this project is just about wrapped up!
  • 2 months later...
As far as I know! I sold the car to a nice guy in San Francisco. He had worked on older cars before and seemed to really appreciate its character, so I think it's gone to a good home. In the end I put around 3k miles on the Porsche. How's the Baum tool treating you?
