Hello,
Does someone had problems with switching low/high range gears?
When I try to switch low gears when car is running (key position 2) - nothing happens, but when ignition is in position 1 (car not running) and I try to switch in low gears - middle red LED flashing on knob, BUT still nothing happens.
When I go into OBC menu >veh.info it says Reduction OFF & Locking OFF.
Btw, diagnostic tool not giving anything.
If someone had this probem solved, please enlighten me!
I've already did it that way. Nothing happens.
When I start the car, those 3 LEDs on console flash once, if car is not running, but ignition is ON, only middle LED flashes couple of times when switching. But if car is running, in neutral and brake applied, no LEDs flashing and no sounds from switching under the car. Fuses all good.
