I am changing the oil filter on my MY05 997 today. I think the plastic canister already hangs down a bit below the oil pan. My understanding is that the LN spin-on adapter with a WIX/NAPA filter will hang a little lower yet. When I eyeball this it sure looks like the factory canister is already the lowest point under the car.
Any comments regarding ground clearance from those using the LN spin-on adapter?
If you have both the adaptor and filter to look at, you will find that the adaptor fits nearly flush into the current canister's opening (just a thin lip protruding), and when you add the spin on filter, the combination is actually very slightly shorter than the OEM unit.  You will be fine.
Thanks for the quick reply. I have not ordered the LN adapter yet, nor do I have the WIX/NAPA filter. Given your input that the combo is shorter than the stock canister I will likely go that route.
