MY05 C2 coupe 6-sp.
I'm sure that this question has been asked before... I did a couple searches with no luck. I'd like to change my oil filter without changing my oil. Have you done this on your 997? Comments?
Edited by j_beede
MY05 C2 coupe 6-sp.
Sure, why not?  When you change the filter, you only lose the oil in the canister, which is less than a liter, so be prepared to top it up.
The only reason would be if the top of the filter is below the crankcase oil level. Better to ask than be surprised I think.
We have changed the filters without any problems.
