Thanks!  Here are the parts you would need from Ebay
1)  the controller:
     http://www.ebay.com/itm/New-popular-controller-of-Led-daytime-running-lights-DRL-auto-ON-and-delay-OFF-/291485890929?hash=item43dde9b971
2) The LED light:
     http://www.ebay.com/itm/2-X-White-9-Bright-LEDS-Daytime-Running-Light-Waterproof-DRL-Auto-Fog-Lamps-/391048902830?hash=item5b0c54b8ae
I mount the light to the existing slot underneath the front bumper signal light using 3M double sided tape and guide the wire toward the engine bay.  From there continue guiding the wire toward the driver side of the car.  From there I tap the electrical wire to the controller and on the other end of the controller to the vehicle power supply located inside the engine bay.  The power supply I tap to is where you normally jump the vehicle with when the battery were low.  The LED light will come on automatically when the engine is running and will shut off automatically after approximate 15 seconds after you turn the vehicle off.  Hope it all makes sense and good luck with your install.
