I have a custom wing installed on my 996 and the normal engine hood wiring harness is completely disconnected (because there is no engine compartment fan etc) so my 3rd brake light is not working anymore. Using the attached diagram, I tried to trick it by shorting pins A2->A8 then A6->A8 and finally A5->A8 which only resulted to blown fuse. What kind of connection should I make to enable the brake light?
post-99919-0-71079800-1435065735_thumb.p
