Hi All
I have found 2x plastic caps in my centre console. They have part number 996 583 421 01 ( as far as I can make out ). I have attached a photo to see if anyone is able to help identify the items.
Hi All
They are intended to protect the surface behind the the holes in which your hard top posts are inserted (behind your back seats) when your hard top is in place. Open side faces toward the front of the car. I've seen many posts exactly like yours .... so I knew what mine were when I found them while vacuuming my used Cab.
Kim
