I brought my 996 to the dealer to get the changer input activated for the CDR-23 head unit. The  tech was unable to find the function in the PIWIS software. He also changed(by accident) the AM  Tuner to a European tuning standard(tunes 9's instead of 10's). Does anyone know where the function is located in  the software to fix both of these issues?
The coding for the CDC needs to be set in PCM>Coding>Required Equipment. First, go to PCM>Coding>Actual Equipment and make a note of the position of each component in the register. Then go to Required Equipment, and edit each position to match the Actual Equipment.
IIRC The tuner settings are in PCM>Coding>Settings.
Edited by Richard Hamilton
