CTEK Comfort Indicator Panel Installation in Cayenne w/images
Here is how I installed my CTEK Comfort Indicator Panel.  I decided to install it under the driver's side dash for convenience, aesthetics, and to prevent possible damage if I were to forget it was plugged in.  There are two different lengths of this type of plug; one is 4.9', the other is 10.8'.  I installed the 10.8' cord because I wanted more options of where I could install it.   In this mod, I used the following: Small Flat Screwdriver T-20 Torx Driver 6mm, 8mm & 10mm Sockets w/ Ra
