Cayenne Front Tie Rod Replacement
Text is located on each pic. Follow pics in the order they are labeled. IMO, you will find it easy to just read each step, make sure you understand what it asks you to do, then do it. If you have any doubt, chime away and people on this forum will help. Hope it helps you out. NOTE: On driver side, the tie rod rear side does not have a shield to remove. One less thing to think about.     *** EDIT***  - I was gone for a while and all my pics had been removed from my tutorials.  Regar
