Folks , I found some interesting information with regard to changes in car behavior that you can expect when you change certain settings on your car.
NOTE: This came from a Kart site so it has some Kart specific information , however , the rest seems to be relevant to us all.
Tech Tips
Chassis Performance
If Kart is loose in rear (oversteer)
1. Wider front track
2. Narrower front tires
3. Narrower rear tires
4. Wider rear tires
5. Higher air pressure in front
6. Lower air pressure in rear
7. Move weight to rear
8. Loosen rear bumper
9. Increase frame flex
If Kart is pushing (won't turn)
1. Narrower front track
2. Wider front tires
3. Wider rear track
4. Narrower rear tires
5. Lower air pressure in front
6. Higher air pressure in rear
7. Move weight to front
8. Tighten rear bumper
9. Decrease frame flex
Air Pressure
Higher
1. Less bite (looser)
2. Reduce bicycling
3. Less sidewalk flex
4. Tire will wear in the center
5. Sme effect as a darder tire
Lower
1. More bite
2. Reduce loose condition
3. More sidewalk flex
4. Tire wears on outside edges
5. Same effect as a softer tire
Track Width
Front Narrower
1. Front will bite more
2. Steer easier
3. Rear will bite less
Rear Narrower
1. Rear will bite more
2. Front will bite less (push more)
3. Lift tire easier (less axle flex)
Front Wider
1. Front will bite less
2. Steer harder
3. Transfer more weight
4. Rear will bite more
Rear Wider
1. Rear will bite less
2. Front will bite more (less push)
3. More axle flex
Hubs
Short
1. More front bite
2. Transfers more weight
Long
1. More rear bite
2. Transfers less weight
Have fun
HarryR C2 1999
