One pipe is damaged in my AC system, and because of this there is a GAS leak and the AC is not working.
The original part number is 95557372201
Perhaps there is any cheaper alternative? Can this pipe be made by some other company?
$192 is the cheapest I see.  Doesn't seem to be anything aftermarket specifically for that part.  I seriously doubt there's going to be any other source for a rear AC line for a cayenne since I don't think even the toureg's have that option.  Someone could custom bend the tubing, but they would still need the fittings on the ends, so you're probably best off finding the cheapest oem supplier you can.
