The drivers side door lock on my 957 TT is not giving contact anymore. The mechanical part functions well, the door opens and closes. The problem is when I open the door the interior light does not go on. Porsche service said that I can get locked out.
They advised to replace the Front Door lock part no: 95553101508 together with the door lock rivet 90825801
The question is perhaps it is possible to repair this lock? What to check for.
It sounds like the micro switch. I have not taken apart the cayenne door latch off but if it is similar to the Boxter's which my Audi TT uses, the $7 micro switch goes out causing exactly the same issue. Try giving it a good clean with WD 40
just in case its merely dirt before removing.
