Hi All,
I'm in need of some help before the car goes off to a car audio specialist. I've run a search on this forum and others but I've been unable to find the answer.
I have a 1998 996 Carrera with the 10 speaker system and factory amplifier.
I have installed a GT3 centre console delete and as such, I have had to relocate the climate control system to the upper dash.
I've also had to remove the PCM1 system and replace the horseshoe surround to support a single DIN head unit.
With the PCM1 removed, I'm left with four connectors. Two of which (wider blue and black connectors) are not needed as far as I know.
The multicoloured connector and the black small connector fit into the adaptor I bought. I've seen others use the same adaptor.
This then connects to the harness that came with the new head unit. Once the 4 RCAs are connected, I've then attached the blue remote wire to the remote signal wire from the head unit.
The head unit powers up as normal but I get no sound.
Can anybody help?
Hi Richard,
I've tried that but I still get no sound.
It's going into the workshop in a few weeks.
