I believe it to be a micro switch and not the regulator...there is a reset procedure...if I did it correctly, it did not solve the problem...at least the windows drop when the top lowers.
To re-learn: press hold window down switch - continue holding for 10 seconds once it reaches all the way down. Do the same for window up - press and hold for 10 seconds.
Re-try the window drop - if it still fails then see these other posts... you really need to try a simple search...
http://www.renntech.org/forums/topic/11050-power-window-issue/#entry53966
http://www.renntech.org/forums/topic/8248-window-issues/#entry40691
http://www.renntech.org/forums/topic/33954-window-drop-down-issue/
http://www.renntech.org/forums/topic/19348-window-drop-question/
http://www.renntech.org/forums/topic/16876-driver-side-window-not-working-tried-almost-every-solution/#entry84657
