LED Daytime Running Lights
I’ve installed a modified 997 GT2 F/G bumper that fits my wide body 2003 996. I opted for the Porsche factory LED lights that were included with this bumper. The LED lights came with a control box, but I still had to connect them so they would work as DRL’s. The following is how I did that. I’m guessing if you used LED strips or other LED’s that were housed in an assembly the following install would be the same. Connecting your new LED lights is pretty easy. I’m assuming that you already h
