Hello,  After moving my 01 Boxster from the driveway, I noticed a piece of rubber on the ground.   The rubber piece located on the ground directly under the engine.   In the attached image, the inside of the curve is part of the design, as well as the outside of the curve.   The ends are where the rubber was torn.
The thickness of the rubber is approx 5.1mm
Does anyone have an idea as to what part this piece of rubber could belong to?
post-19869-0-17349700-1431041616_thumb.j
