I have a 2006 997 C2S Cab and the Bose Sub Woofer Amp is draining the battery. Turn the car off and amp stays on I am assuming. Next morning battery is dead. Did all the battery checks and installed new battery as well. Not the battery. I have unplugged the sub woofer assembly and that solves the problem. Sub woofer unplugged and next morning car and battery work just fine. I have been told the amp relay is stuck closed and therefore drawing power. New part from Porsche is 950. The relay, if I can get it is 2 dollars ....if that is the issue. Anyone have this experience and a solution?
Thx
