The seat belt adjuster clip has fallen off and I can't put it back on without getting behind the slider mechanism (to push it out while pressing the adjuster clip back on). I have a plastic trim remover lever, but it doesn't seem to pop off - what am I missing!
No screws that I remember. Just clips holding it in place. Get a long flat screwdriver and pry it at the base of the clips. There is a wire connector. But you shouldn't have to unplug that. Might be helpful to get your fingers behind the door seals.
This is for a early cayenne.
Took me ages to figure it our.......A torx screw behind the plastic label denoting 'Airbag'. All sorted now :-)
