Hi everyone. Thanks to the help on this forum, I performed my first oil change this past weekend. Everything went well. A bit later in the day I took a reading and it read low. I put more oil in, but I guess I hadn't let it all settle because now the gauge reads one bar above the max line. Will this hurt the engine? Would you recommend doing another oil change or just allowing some of the oil to drain out by loosening the plug? Thanks.
It is covered in the owners manual.  One bar is something like a few cups of oil.  Ignore it and have fun with your car.
I was hoping that would be the answer. Thanks and next time I promise to rtm first :D
