Hi guys!  Recently bought a 2001 911 C2.  Radio has no power... nothing... pressing all the buttons does nothing at all.  I pulled the radio and replaced the 10amp fuse in the back (couldn't tell if the old one was blown or not because the metal fuse part is not visible in the old fuse.)   Radio fuse in the kick panel in the driver's side footwell is fine.  Still no power.
Any ideas?  Maybe the headunit is shot??
Edited by ksteak
Least you can do is to measure whether there is power and ground on the radio connector, unless there is a interruption between the fuse box/grounding and the radio. If this is considered to be OK, only then the radio can be seen as a possible suspect.
