hi all, i have searched and found info on rear drains but not the front sunroof drains.
2006 997 c2 coupe.
front 2 trunk drains were clogged and are now cleaned - is there more than 2 to worry about?
Sunroof drains - went through the car wash the other day and there was a wet spot in the front drivers corner of the headliner.  I am assuming this is the sunroof drains.  I have found info on getting to the rear drains by removing the headliner (is this a brutal chore or not too bad?)
But I have looked al over with little success on the front drains.  I am assuming you have to also remove the headliner - any info on this?
Is there anything else I should be checking regarding this?
thanks
brent
There are four drains, one in each corner, left & right, front & rear.  The fronts can be accessed without removing the whole headliner, just the front portion.  The rears  might need the headliner taken down.  I just posted a link to rennlist in another thread that has more info on the headliner removal process.
