Check engine light is on. Used the durametric to get the codes. I just did change the valve cover gaskets not too long ago. Not sure if that would be related. Where do I start?
Work Log
  Bosch Digital Motor Electronics 7.1.1
Module Identification
                 VW Part Number      8SLVAKN00000 Controller ID      0134       Current Fault Codes
P2235
Lambda control adaptation at idle, Bank 1 - Upper limit value exceeded, test conditions are not-completed, fault is currently active and causing a DTC light
P2237
Lambda control adaptation at idle, Bank 2 - Upper limit value exceeded, test conditions are not-completed, fault is currently active and causing a DTC light
P0011
A Camshaft Position -Timing Over- Advanced or System Performance B1 - Implausible signal, test conditions are not-completed, fault is not currently active and is not causing a DTC light
Edited by seafeye
  • 7 years later...
