I'm having trouble finding the part number for the main light switch that comes on when door is opened (or can switch on/off), the one on the ceiling in front of the rear view mirror.  To clarify, the light seems to go on and off due to poor connection so maybe I can modify instead of buying the part.
Also, the two knobs on the instrument cluster to change the clock and reset the odometer - can those parts be found and replaced or connected to the cluster?
MY2005 base
In case anyone else ever needs it, I found the knob part numbers:
Knob trip meter: 95564101000
Knob clock: 95564107010
Each costs about $32.88
The next question is if replacing the knobs is what's needed to have them work again, and if install is simply a pull and replace without taking out the cluster
And interior light is 95563205100
Edited by OU Targa
