I am planning to replace the defective aspects of this system because of recent error messages I am starting to get.
I see there are two parts possible to use:  1.) a clutch pedal switch (red), and 2.) a clutch pedal ignition lock switch (white).
Must I replace always both, or is one usually the culprit in this failure mode?
Should be easy to test (out of the circuit) with an ohm meter.
Open = infinite ohms. Closed = zero ohms. Anything else or intermittent is a bad switch.
OK, thanks,
actually someone else recommended a jump between it to prevent it in general, of course deactivating the system entirely, which some may find a safety issue with it not in neutral, but aside from that, what is the procedure to do this and how to if so?
