I test drove an 04 ctt with 80k miles on it. No real big problems, except the front doors rub/hang up a little on the center pillar cover at the top. If this was an old Targa or 914 it would almost seem like frame sag. Anyone seen this? I am perhaps too critical.
Edited by ARModen
I think it's actually simpler.  They have some aftermarket windscreens around the front and rear windows, which I think are stretching the rubber out a little bit.  The whole rest of the door lines up nicely.  They have also installed a similar screen in front of the sun roof.  I'll probably just remove them all and see if that fixes it.
I decided to buy it because 14K isn't bad for a CTT, and I like projects.  The next one is hacking the most system to update the software and get the amp+CDC working. Anyone know how to pull up software versions?  I read something about pressing multiple buttons at once, but apparently it was not the same version of the PCM so it didn't work.  Sadly the durametrics doesn't seem to interface with the MOST/PCM systems at all.
Edited by ARModen
