The CEL came on today so i pulled out the Durametric and found 2 codes
P2677: O2 Sensor Pumping Current Trim Circuit Bank 2 Sensor 1 - No Signal/communication, test conditions are not-completes, fault is active and causing a DTC light
P0150: O2 Sensor Circuit Bank 2 Sensor 1 - Implausible signal, test conditions are not-complete, fault is currently active and causing a DTC light
Where should i start looking for a problem or is it as simple as an O2 sensor?  if so how do i test the sensor to confirm that is the problem.
Check fuses then inspect the wiring to the sensor, if everything seems in order replace the sensor.
