Hi All,
I need a little help diagnosing a problem.
So I was driving home in the rain the other day, and multiple warning lights began going on and off.  The volt meter was also going up and down as well.  From alternator levels around 14 to battery levels around 12.  The problem is not the alternator, I already checked that off the list.
Warning Lights on:
Hazard
PSM Off
Spoiler
Park
Brake Fluid
ABS
Battery
Seat Belt
Any help would be appreciated.
post-77991-0-93185300-1428094406_thumb.j
Second what Loren suggested. Also check the battery cables, terminals to make sure the connectors are tight. Also, check the ground cable on the engine right side behind the right rear wheel.
Edited by Ahsai
Thanks Guys,
I'll check all that tomorrow morning and get back to you.  Maybe switch in a battery I know is good.
Thanks for the help!
Jon
So I took out a multimeter and tested the battery.  It did need charged, even though it was starting the car.  I tested the battery after charging, and it is good and holding a charge.  So I turned the car on and put the multimeter on the battery while running, and the voltage dipped to just above 12v.  Which to me would mean the car is running straight off the battery.  I'm hoping the problem is the ground strap, but I don't know if that would affect it.  Otherwise I would assume more serious wiring issues.
Any thoughts are appreciated.
Jon
Sounds like the alternator to me. Check out my write up here and do test #5 first, which tells you whether your alternator is bad. http://www.renntech.org/forums/topic/47504-troubleshooting-low-voltage-and-charging-issues/#entry265666
Then use a jump start cable to connect the engine brace behind the rear bumper to the brass bolt on the airbox close to the engine lid lock. That will bypass a bad ground strap.
Edited by Ahsai
Just to let you know.  It was the alternator.  I used a wire to test the back.  Got a new alternator in and everything is good.  Looks like I shouldn't have assumed a brand new alternator would work!
