I am sure this has been covered, but I will ask anyway. Small bumps in the road will make the drivers door clunk. This is tolerable. The passenger door makes a loud squeaking noise. It is coming from the rubber on the upper door frame near the lock. I have tried WD-40, other silicone spray, degreasing the metal, etc. to eliminate the squeak. The last attempt was Gummi-Pflege. it is  the rubber making contact with the metal frame. Has anyone had success removing this?
