P0413 Generic Secondary Air Injection System Switching Valve 'A' Circuit Open
I got this code 3 days ago after the dealership replaced a relay and mass flow air pump. How can I fix this on my own?
Also the Vehicle Four Wheel Drive System Faulty light comes on and off. How can I fix this problem?
2006 Porsche Cayenne
Do you mean the Mass Flow sensor? No Mass Flow pump that I know of. What relay did they replace?  Need the scan of the 4wd/transfer case but the transfer case stepper motors are known to go bad but not very common on '06 and later ones as they had later revision/improved? motors supposedly. On the earlier ones Porsche recommended replacing the motor with a new control module but I think that was only for the '03/'04 years as your '06 would probably have the newer software. Really can't be sure without a scan. Have you tried to engage/disengage your center differential?
P0413 Secondary-air solenoid valve driver – open circuit
Possible cause of fault
- Fuse F50 faulty (fuse carrier on left of dashboard)
- Open circuit in voltage supply in secondary-air solenoid valve
- Open circuit in ground supply in secondary-air solenoid valve
- Secondary-air solenoid valve faulty (resistance too great)
- DME control module faulty
Always start with the fuse.
