Hi all, just wondering if someone could give me exact dimensions of the steel ring in this pic?
I dont really want to remove and strip my strut just to measure it. ID/OD and thickness would be awesome if someone had one sitting around (bilstein unit).
Thanks from Ireland :)
Are you speaking about the spring compensation plate?
If so, it's thickness will be color coded - to the spring tolerance.
no its the steel ring that slides down over the strut body for the bottom of the spring to sit on. Actually the diameter of the strut is 50mm so the ring has a slightly larger ID.
