2005 997S 3.8 Couple of days ago I was driving to work as normal, all dash indications normal and up to operating temperature. The whole car 'hiccoughed' the engine just appeared to stop dead for half a second and then resumed as normal. No lights came on not even a rpm drop that I saw,nothing out of the ordinary. Connected durametric, no fault codes stored at all. Monitored cam deviation angles v rpm throughout the range from idle to 6000 rpm, all good. The only thing I did before the journey was to top up the oil by 0.4 L bringing the level up to 3 bars rather than 2 bars full. This has happened just the once so far, but it is concerning me. The only thing that I saw that was unusual was that when I turned it off the oil pressure gauge stayed reading 1 bar. Turned ignition on and off and it dropped to zero. Anyone got any idea what might have happened?
My MY05 997.1 coupe's oil level indicator has 5 bars--I believe. Three large bars between the MIN and MAX levels plus a smaller bar below MIN and another small bar above MAX. In the owner's manual it seems to say that the max fill level is 4 bars. Is it your preference to keep your level at 3 bars?
The two "events" you describe sound consistent with an electrical "glitch" in my opinion. For the pressure gauge to show a non-zero value with the ignition off suggests a grounding fault. I will have to take a look at my pressure gauge during idle, then with the ignition switch off, then with the key out.
...j
I think you may be confusing level with pressure. In the UK we have oil pressure gauges in "bar" which is approx 14.5 PSI, it was the oil pressure I referred to. Normal running is approx 3.5 bar or 195.8 PSI ! Thank you for at least responding, I was beginning to think everyone had gone home  :D , but it is obviously NOT a common event to happen. Not happened since so putting it down to duff fuel until proved otherwise.
My error... from the sentence below it sounded like you were talking about oil level. Note: My oil level indicator is formatted like a stacked bar chart.
"The only thing I did before the journey was to top up the oil by 0.4 L bringing the level up to 3 bars rather than 2 bars full."
Theoretically we should be speaking the same language (though in the US "braces" go on your teeth, a "lift" is something you discuss with a plastic surgeon, and "stones" have nothing to do with the weight of your Porsche  :)).
Thanks for the pressure vocabulary lesson. It's been a while but I still recall atm, Torr, Pa, Boyle, Charles, and PV=nRT and other ideal gas law bits. I don't recall much from fluid mechanics. Odd.
I'll adjust my earlier comment by saying that your post-shutdown 1 bar reading could be a pressure sensor anomaly. I assume that disconnecting the oil sending unit would store a code, perhaps a resistive connection (hot or ground) would not?
Hopefully your 997 is in good nick these days. (Did I say that right?)
...j
