I have the Litronic headlight assembly. I am trying to replace the Xenon bulbs as they have become noticeably less bright. The passenger side assembly slides out easy after following the instructions in the manual. The drivers side assembly is another story. I can hear the audible pop when I turn the tool and the assembly moves out about half an inch, but in spite of pulling in all directions will not move any further. Any ideas on what is holding it in place and how I can get it out without snapping some of the lens covering by yanking on it?
Try moving the tool that you used to move the headlight into the "out" position back a bit towards the "in" position and then try to gently pull the headlight out.
