The clam shell stopped opening, I hear the motor running, till the unit times out. I manually opened it, the clam shell motor runs but the output shaft doesn't turn. I removed the unit. part number "996.624.122.00" I found a repair kit part number "996.561.673.00" The problem is that I cannot take the drive unit apart to repair it. does any one know how? I removed the 4 screws that hold the plastic cover to the gear box but it only moves about a 1/8 inch and stops.
Thanks for the help.
