HI Guys,
Great forum. Thank you for adding me..
I have just bought my first Porsche, a 1999 986 (I think) Boxster.
It is in immaculate condition but has a few electrical issues....
1. When I operate the roof, the rear boot pops open. Is this normal or an issue ??
2. When I open the driver door (RHD) the window doesn't stay down, so I have to hold the handle up when I close it.
3. (not sure if  this is normal or an issue) 3rd gear seems to have two stages !?.. i.e. revs drop and it feels like its moving up a gear but still shows 3rd !?
Any help greatly appreciated.
Jason
1) Looks as an issue or programming error  2) Issue, probably microswitch in doorlock failure  3) This is a Tiptronic, normal behavior (clutch lock inside torque converter functioning). There is a lot of info on this site about these problems, use the search button on top right of each page.
Thank you.. I did try searching but found nothing exact though there were many similar issues.. Thank you for your help :)
Is there a way to reset programming or is it a Porsche dealer thing ?
Programming is essentially a Porsche matter, anyway, some diagnostic tools used by independents also provide opportunities.
