Has anyone replaced the upper "pressure pipe" from the intake to intercooler? I'm trying to replace the O-ring in there since I have a small leak. These are the pressure pipes on the top of the engine that go to the top connection on the intercooler. There is one on each side.
  • 10 months later...
That's a pretty straightforward job, made very easy if you remove the air filter housing. This takes maybe an hour. I am writing a turbo removal DIY at the moment that does this as part of the process.
