Hi All,
I was wondering if anyone installed Hella Supertone via straight connect to existing horn wiring, or used a relay and the existing horn wiring as the switch.  If a relay was used, where did you run the wiring? Straight to the battery?
Hey,
I installed the hella supertones as a replacement for the stock horns about 8 months ago, since the oem horns suck on the 955 CTT. Straight wiring, no relay. Just connected to existing wires and added shrink tubing. It's a bit of a struggle to fit them in physically, but i've had no issues with sound or battery drain since then
