My 2012 Cayenne S developed a strange power windows problem. This is happening on one of the rear windows from either button (drivers door or the button on rear door). If you hold the button to close the window on the door or if you press the button on the drivers door for one touch closing the window. The window closes all the way and then immediately opens up again to half way. The only way to close it is to either close it inch by inch, crawling up the the top or by pulling the window up while it tries to close with both hands on both side of the window.  This is pretty annoying. It started couple of days ago. May be some salt from the road got inside when the window was opened with salt deposits on it and its causing some issue? I really am not sure how power windows work on this car and if this is a common issue that other people have encountered. Any help would be appreciated. Thank you
:welcome:
Have you tried "re-training" the window?
That is, press and hold the down window until then window is all the way down - continue holding it for another 10 seconds. Do the same for window up not releasing for 10 seconds after it is all the way up.
Then test and see if it performs as it should.
