So I had this airbag error on and had taken the car in to look at it. After few hours of pd they say SRS Module is most likely bad and they would have to buy to put in.
The part is $1200. Since electronic, can't return once plugged in. So once I buy, I spent the money even if there is secondary issue.
Shop asked me if I want them to start debugging but I would be charged hourly fir time and then for repairs.
Shop appears great reputation and recommended by many.
What would you do?
Here is the more detailed info of errors
ME:
P1627
CAN timeout - airbag - Implausible signal, test conditions are not-completed, fault is currently active and is not causing a DTC light
Instrument Cluster
1321
Airbag triggering unit - No signal/communication, test conditions are not-completed, fault is currently active and is not causing a DTC light
KESSY
1321
GATEWAY
1321
So after some lengthy troubleshooting I was told definitely srs module out. Since dealer part I was told 1200 for part itself and 300 for install, programming and part of troubleshooting time.
They said took about 5 hours to determine this.
Does that sound decent or am I taken to the cleaners?
