Folks, i noticed the car was idling a little rough btwn 400-700rpms and wouldn't hold and idle smoothly at 400rpms.  I purchased an OBD scanner and pulled the above fault code. I did some searching on the site and i see similar issues pointing to MAF, throttle body or intake leak.   The MAF was already replaced about 10k miles ago.
Any other thoughts?  i have to swap the winter tires over, so will likely have the shop address it.
MY 01 996 carrera 2 ~35k miles
Edited by greg0078
P0507 is a throttle position actuator code, indicating a higher RPM than expected.  While intake air leaks will cause similar problems, they typically result in other codes (overly lean mixtures).  Your throttle body may need cleaning or replacement.
Thanks JFP.  I found the DIY on cleaning the throttle body so i figured i would give it a shot. I am a mechanical imbecile but like to learn. After watching a youtube to get the air cleaner removed, i wiped out the throttle body. and cleared the CEL.  I did not have carb cleaner so just wiped it out.  I did see a brown ring. Appears t be idling better, i'll give it a few days and see if throws another code
thanks all
Thanks Ronnie that's a good call. I just canceled the throttle body and carb cleaner, and ordered maf cleaner. Thanks for pointing that out.
