I am having trouble inserting the replacement shock into the rear of the car. I have compressed the spring and reassembled the entire strut but cannot get it fully inserted. when I get the top of the assembly into the fitting, I cannot move the shock up enough to fit into the bottom mount. Any suggestions would be appreciated.
Loren,
Thanks for the response. I am not sure what you mean.Are you talking about removing some suspension components? Do I need to compress the spring again with the shock in the car?
I am unable to get the top of the shock lowered enough to fit into the three holes after putting the shock in the lower carrier. It wedges in to the underside of the wheel well. The top needs to compress about 3 inches to fit.
Okay, I see now.
You can rent or buy a spring compressor or...
Attach the top 3 studs and bolts first - then carefully use a bottle jack (or floor jack) to push the bottom of the shock up to the mounting point.
