I am trying to remove a K&N cold are filter to clean it. I have removed the clamp. The filter spins but I can't seem to get it off. Suggestions???
Its on a 2004 996
Edited by Dstewart73
Cannot help with this, but if yours is an oil coated filter, watch out had one on my Z3M and the oil coated the MAF sensor and had to replace it. Hope fully K&N have solved this problem.
Problem usually isn't with the factory oil coatings, but rather with the amount of oil put on the filters when they are first cleaned by the owenrs.  Done right, they should not cause problems.
