Hi, new to the forum
I have just bought a stolen recovered 1998 lhd 996 with no dme and alarm module
Does anyone know if a dme, alarm module and key pill from a 1998 uk car will work and get it running
I think the car was originally from Germany
Many thanks Matt
:welcome:
The alarm module, DME, and transceiver are all programmed together - so theoretically that could work.
If the car is originally from Germany then the cats are likely a different spec - you will need to check local laws to see if they are approved for use in your country or not.
Thank you for the fast reply
Can u see there being any problems with fitting a RHD dme, immobiliser and pill into a LHD car?
Thanks Matt
