After  letting the car without a tender for the battery the battery was completely drawn. Charged it. Showing 12.9+ volts ans the car won't turn. Battery gauge shows 12 + volts. Correction, it won't turn..
Any ideas?
996 MY 99 6 stick shift.
Edited by hi8ha
The cluster lits, tried to jump start connecting jumper cables to the prongs on the engine bay but no cigar.
Have you tried jumping the clutch safety switch? Can the key fobs arm/disarm the alarm?
Checked fuses c1 to c4? How long has the battery been dead?
Edited by Ahsai
The battery been dead for, I think, more that 2 weeks. The key fobs are not working for a long time and I was able to start the car with the non working key fob..
Will check the fuses. Where are those fuses located, on the fuse box by the driver's side foot-well? The foot clutch safety switch was working on the last tie the car ws started. After the battery was drained drained and charged , the car did turn/start, but after doing a complete battery charge, it won't turn.
Yes, fuses are at the driver's foot-well. Most likely you need a new battery anyway so may as well put one in and retry. Deeply discharged battery most likely cannot be revived.
Will check and keep you posted. Thanks for the advise. Can a battery have the right voltage but low AMPS? Think that may be the cause of the problem.
Edited by hi8ha
Things that are left unused for a long period sometimes don't work as they should when re-connected.  What is the voltage reading from the battery and does it drop when you try and turn the key to energise the starter?
As Ashai said it could be the clutch switch.  Depress the clutch a few times and operate the starter switch a few times, it might clean up the contacts.
Update:
Fuses OK. By-passed clutch switch..... Running.
Thinking of by-passing the clutch switch for good.
Volts reaching battery 14+, volts at jump points (engine trunk) 14+.
Will drive the car and see if battery (Optima) will hold charge.
THANKS FOR YOUR ASSISTANCE EVERYBODY.
Edited by hi8ha
That's good news.
The clutch switch could fail intermittently when it starts to go bad. You may want to replace it with a new one and make sure you hear it clicking at the end of the clutch pedal travel. There's some small adjustment that can be made on the mounting screw. The switch does provide some safety if you accidentally crank the car when in gear.
My 2003 996 Cab is exhibiting intermittent problem I think is related to clutch switch. On occasion, after depressing clutch, engine barely turns over, acting as if battery is dead. Battery has been tested and is fine. I'm not sure why clutch must be depressed all the way to the floor when switch appears to pop out after first inch of clutch pedal travel. Any ideas would be greatly appreciated. Thank you in advance.
On 3/5/2015 at 4:55 PM, hi8ha said:
Update:
How do you bypass clutch switch?
Figure 1 in the second link Schnell posted above, remove the two wires from the grey switch and bridge the two terminals of the wires with a bare metal paper clip. Just make sure you put the gear in neutral before you crank the engine.
Edited by Ahsai
I use one of these to jump the switch.  Nice and tidy and easy to do/undo by feel.  Not as cheap as a paper clip but handy to have in the glove box just in case.
Edited by rockhouse66
