Chicagospeed...  I have a set of motor mounts out of my 2003 C4S with 60,000 miles that are good, and I would sell cheap...
Ah yes. Mine only have 39k on them. So yes 60k would not be an improvement. The corteco ones are more expensive. I think the Beck ones in that link are stock replacent and a OEM supplier.
I have quite prominent wheel hop in my 02 Carrera (140000 km), I guess my engine mounts are shot. Which should I buy to eliminate wheel hop? New OEM, semi solids, any reccomendations.
2016-04-22 14.12.16.mov
While I am in diagnosing a cracked head I changed out my rear mounts.   Easy job, but glad I did -- '99 - 84000 miles and had developed a slight vibration right at idle - would go away slightly off idle - I hope this cures it.   Video - new on left - completely shot on the right!
I bought the Rein ones from autoatlanta. Mine were at 55,000 miles but 18 years old. You can see the difference between the used ones and the new ones.
post-100493-0-89575100-1461584986_thumb.
