the radiator fan in my 09 CTTS has been running none stop at high speed lately in -30C freezing weather.
I plugged in the Durametric and it shows the following code:
0480
Fan 1 control circuit
No signal//communication
any suggestions?
thanks
P0480 Fan control output stage 1 - open circuit/below limit value/above limit value
Possible cause of fault
- Break in wiring in power supply to fan module 1 (large/to the right)
- Break in wiring in ground connection to fan module 1 (large/to the right)
- Open circuit in control line to fan module 1
- Short circuit to ground in control line to fan module 1
- Short circuit to B+ in control line to fan module 1
- Fan module control module 1 faulty
- DME control module faulty
thanks Loren, you are the man!
so it seems most likely it is related to the wiring?
Edited by royxaxa
