So I had the airbag light turn on one day and it stayed on even after clearing with durametric.
I read the forums and thought it may be something more serious. But then my wife drives the car and comes in to tell me that the driver seat belt does not sound alarm if you forget to buckle it up. Typically if you drive without buckling up, the alarm would go off. She noticed it did not and I confirmed.
Could this mean the airbag light is off because of something to do with the seat belt sensor?
I lifted driver seat up, followed the wire from seat belt clip to the connector (front of seat, yellow 2 wire connection).
Seemed solid enough ( used DMM to check continuity and it was there).
However issue still there (airbag light on).
What domyounthink about this and do you have recommendations on how to proceed from here?
Thanks.
